F-150 2005 Putting Tach In Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2005, 02:57 PM
My son in law is trying to put in a tach in his 2005 f-150 truck 4.6 liters . We are having trouble finding the ignition coil on the truck. the tach is a Sunpro and the green lead is the one that goes to the ignition coil . Also is there anyone out there that can lead us to a breakdown of the ignition system on this truck and have an exploded view on the web. We want to make sure we hook this up right so we do not fry the computer.
Thank you for your help,
Dobie1965
Old 07-17-2005, 06:34 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
the mod motors run coil packs. If i'm not mistaken you have to get an adapter to hook up an after market tach on those. but i'm a schnook. post your question in the electrical forum, or if you haven't already, try a search on "mod motor tach" and see if theres anything there.... btw welcome to HR.com
Old 07-17-2005, 07:19 PM
aka Duke of URL
-From F150 Online Forums-
I thought I had seen an adaptor somewheres also, but of course can't remember where.
Old 07-17-2005, 07:44 PM
poncho62's Avatar
Wiki Edits: 5
Going tp move this to the "Electrical" forum........maybe Doc, our resident electrical guru knows about this...............
Ontario Rodders
Old 07-19-2005, 06:41 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
Hmm....I believe you have to take the signal off the ECM itself. The '96 crown vic I owned had a tach output right on the coil pack. The newer mod motors use coil-on-plug, so you can't just plug a tach into a coil pack like on the older ones. I believe you will have to use the same line that is used by the factory tach. I'm not sure if you will need an adapter or not. If you get a shop manual with the wiring diagrams for it that would help a lot.
Not a huge dis, but if he wanted a tach why didn't he just get a XLT which has it from the factory?
My 2004 is a V6 5sp and I don't have a tach.....have never had a problem.
Sun Tach 383vette Electrical 6 12-30-2011 02:21 PM
94 chevy truck runnin' like poo! bluesmanjesse Engine 11 11-09-2006 02:54 PM
factory tach 81-87 chevy truck djtejas Electrical 5 10-12-2004 02:06 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
Ebay Truck Headache CrashFarmer2 Hotrodders' Lounge 8 09-06-2003 07:30 PM
