Is F-150 headlight relay in switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2005, 07:34 PM
cboy's Avatar
Last journal entry: Finished
I'm attempting to adapt the 1981 F-150 wiring to the rat project and I don't see a headlight relay with the wiring I stripped off the F-150 or in the wiring diagram I have. It appears, based on the size of the wiring, that the relay might be inside the switch itself. Anybody know if this is the case?
Always learning...and sharing what I've learned.
Old 05-25-2005, 08:33 PM
302 Z28's Avatar
As far as I remember the 81 F150 has no headlamp relay, either external or internal to the switch. The switch carries the entire load.....I think.
Vince
Old 05-25-2005, 09:49 PM
cboy's Avatar
Thanks Vince,
Here is a pic of the switch if you can tell anything from that. The large black/orange wire on the left comes directly off the alternator regulator (no relay) and appears to be the large capacity wire to feed the headlights.
Name:	trans hump 028.jpg
Old 05-26-2005, 04:42 AM
302 Z28's Avatar
Yep, that is the bugger. I also think the switch has a built in circuit breaker.
Vince
Old 05-26-2005, 06:47 AM
cboy's Avatar
Hope so because I can't find a fusible link anywhere in that heavy wire coming in from the regulator (according to my manual, Ford used in-line links and not the plug in modular fuses for the F-150). Also the wiring diagram does not show a fusible link in any portion of the headlight system. Guess I'll just wire it up and keep the extinguisher handy.
Old 05-26-2005, 07:45 AM
aka Duke of URL
There was no relay in that circuit. The switch carried full amperage. FORD had trouble with the trucks that had marker lamps on the cab as the required amperage through the switch would actually melt it. The only circuit breaker is for the tail/brake lamps.
You really need to put the headlamps on a separate circuit via a relay.
Old 05-26-2005, 08:08 AM
302 Z28's Avatar
I strongly agree.
Vince
Old 05-26-2005, 10:32 AM
aka Duke of URL
-TECH ARTICLE-
Old 05-26-2005, 11:47 AM
cboy's Avatar
Great "how to" Kultulz. Thanks for the following up.
Old 05-26-2005, 01:12 PM
cboy's Avatar
I found two new relays in my electrical drawer but I don't recall now what amp rating they were when I got them. I don't see any markings on the outside that sound like a rating number. They are marked with the normal 30-85-86-87 and 87a for the tabs but the only other numbers on the case are 49400 on the top of each of them and then one is stamped with a 030 on the back and the other is stamped 103 on the back. Are relays typically 20amp or might these be lower.
Old 05-26-2005, 04:47 PM
302 Z28's Avatar
Those relays typically are either 10 or 20 amp. You can get 30 amp relays in th same format.
Vince
Old 05-26-2005, 05:47 PM
cboy's Avatar
Any way I can test or tell for sure what these are?
Old 05-26-2005, 07:18 PM
302 Z28's Avatar
They will probably handle the load you require, but these things are cheap. Trash them and buy some that you know the amperage of and play it safe.
Vince
Old 05-26-2005, 07:35 PM
SS Blazer's Avatar
The headlight switch has a thermal circuit breaker in it. It will cause the headlights to blink when it gets too hot. This will most likely happen when the lights are on bright for a extened period of time. The relays are not a bad idea to keep the load off the switch.
Help Wiring A Relay to A Dash Switch horvath Electrical 6 03-06-2005 01:58 PM
headlight and wiper switch dusterbd Electrical 3 01-02-2005 08:26 AM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 08:31 PM
80 Trans Am Headlight Switch jdcoic Electrical 4 09-10-2003 03:19 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
