F-41 Suspension Specifications GM G-body? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2004, 05:36 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
F-41 Suspension Specifications?
I have not been able to get specifications on the F-41 suspension components.
What all is included in this package?
I have done a search on all the bulletin boards I belong to and only came up with the following:
Braces from mid-fender to radiator support near radiator.
(I have these)
Braces that criss-cross the radiator support in front of the radiator.
(I have these)
Braces that connect the front frame from just behind the front body mount to the crossmember under the engine.
(I have these too)
The front sway bar is the larger of the two sizes I have seen offered. (dont have)
The front springs are rated at nearly 420 pounds spring rate.(don't have, but think a V-8 wagon with A/C and heavy duty cooling would be pretty close)
The rear should have a 1 inch sway bar. (don't have, but soon will)
The shocks, their application, and spec's I have not found anything, so I need a little info here.
I also plan on adding the trunk bracing when I get a break in my car show schedule, and have seen pic's of bracing at the rear of the chassis, and am considering that too.
I have also swapped in a quicker ratio power steering box with a 39 degree turning angle.
Old 06-18-2004, 06:28 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
ANYONE............
I have this same exact post on THREE other boards I belong to and have yet to come up with anything more than my own searches on the net have yielded.
One post on another board referred to a front spring rate of 420 # per inch, and there should be a different shock but I haven't been able to find that info.
If I find out I will post it here for reference purposes, as it relates directly to all GM A and G body cars, I even found out some also applies to B bodies too.
Old 06-18-2004, 07:24 PM
roys63's Avatar
What the hell is a F41? Toyota Landcruser? Airplane?
Old 06-18-2004, 07:43 PM
badknuckles's Avatar
you talkin to me?
i think f-41 was a standard 6 cylinder suspension they started badging there 6's to sell them.
Old 06-18-2004, 09:21 PM
RippinRon's Avatar
I have a 86 Olds Cutlass Supreme Brougham with factory f41 suspension its a Canadian car which had a 305chevy/200r4 now has a 350. I believe all canadian olds g-bodies had chev motors but I could be wrong. Anyways my car has 1 1/4" front and 7/8" rear sway bars, it has two braces running from the frame under the oil pan creating a triangle, quick ratio steering, stiffer springs I have no bracing infront of the rad and nothing behind the back seat. Moog 5608 is a direct replacment for f41 front springs which are rated at 420 in/lbs. I havn't heard of the shocks being different. Here are some links
http://www.monte-list.nu/articles.shtml
http://malibunorth.freeservers.com/TechPage.htm
Old 06-20-2004, 07:40 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Not even close.
HA, too funny, , NOT!!!
The General Motors RPO code F41. The Chevy dealer order guide and quick-spec book I have states the F41 "SUSPENSION EQUIPMENT: Suspension, Sport."
It also states the F40 suspension package as: "SUSPENSION EQUIPMENT: heavy-duty, front and rear."
The Chevrolet passenger car value guide I have goes as far as including the description:
"Requires P205/70R-14 steel belted radial white stripe tires. Includes larger diameter front stabilizer bar and rear bar, higher rate springs and matching shock absorbers."
On other bulletin boards I belong to, members have mentioned small things like the bars I have recently installed on my car, as a part of the F41 package.
Old 06-29-2004, 02:57 PM
Im trying to have an idea!
some one asked this question at another forum, i would like to know also---
Where did you get your faster power steering box? Is it also higher effort ala Z28 or WS6? Did this mean replacing the pump as well as the box? I've seen a number of places offering faster boxes, but haven't heard from anyone with after-the-purchase experience.
Posted this for ya over at oldspower.com to see what came up
http://www.oldspower.com/vb/showthread.php?t=13181
