Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - f-bird'88 lift rule 350-vortec
  #36 (permalink)
Old 06-02-2008, 07:55 AM
DENCOUCH's Avatar
DENCOUCH DENCOUCH is offline
Thanks MSTom
Thanks or your efforts. Now, before I part with any greenbacks, allow me a second to see if I am clear on this.
Utilizing flat top pistons will give me a better shot at controlling quench than using dish pistons, true?
I can add the measured piston height to the head gasket thickness to determine if my quench is tight enough?
If quench is tight enough, then I will not build myself into a corner where I cannot run this motor on pump gas?
Thanks for the enlightenment!
