F1 48 thru 52 spindles on a 37 thru 41 axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2013, 12:48 PM
Hey does anyone up here know for sure if a set of F1 48 thru 52 spindles will fit on a 37 thru 41 car axle? The thickness of the king pin boss is the same but I'm worried if there will be an inclination angel issue.
Thanks
Chris
Old 02-24-2013, 05:15 PM
Wiki Edits: 27
supposed to fit.
Everything i've read says they are supposed to fit. I have an f 1 axle with brakes and an extra set of F 1 spindles, I haven't tried to put them together. the stock truck steering arms are Quite a bit different than the car parts I;ve read on the HAMB site about using later drum brake parts to have self adjusters, I think the F1 brakes are similar to the late 40's lincoln brakes The hamb had a list of "modern" drum brake part numbers.
Old 02-24-2013, 06:08 PM
I wont be using the stock steering arms. I'm going to cut them off and grind the area where they were nice and neat and then I will use longer backing plate bolts and after market arms.
Adapting '49-54 Chev Spindles To Ford Axle 27Tall T Suspension - Brakes - Steering 2 05-11-2011 07:05 AM
will 55 f100 spindles fit my '28 A axle? jwk90 General Rodding Tech 3 10-09-2009 10:33 AM
Twin I beam spindles on a solid axle Chevrolet4x4s Suspension - Brakes - Steering 5 10-11-2008 08:41 PM
Spindles on straight axle TexasSpeed Suspension - Brakes - Steering 8 08-13-2006 09:24 PM
49-54 spindles on straight axle help! ptsherman Suspension - Brakes - Steering 4 03-04-2003 02:15 PM
