F1 front end - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2013, 12:51 PM
F1 front end
Has anyone used a Ford Crown Vic front end under a Ford F1 and if so how is it?
Old 07-15-2013, 02:29 PM
MNSAPP's Avatar
1948 Ford F1
Glad to see a another F1 builder on here.
I am building a 1948 F1 right now I have just finished the frame build. I am building this on a tight budget and could not afford to drop over a grand on a IFS weld in kit. So I hunted around the junk yard and trying to stay with Ford parts only. I found that a 2000 Ford Ranger has the same frame width as the 48. So I cut from the firewall forward off the ranger and grafted it into my F1 frame. I have fully boxed in the old frame and placed 3/8 plate over the butt joints. Attached are a few pictures.
Name:	with wheels on.jpeg
ID:	75716   Click image for larger version
Name:	front side.jpeg
ID:	75717   Click image for larger version
Name:	front of frame.JPG
Old 07-15-2013, 02:33 PM
Banned
check out this
Front end ID JMSTOY Suspension - Brakes - Steering 5 12-22-2011 06:48 PM
1953 Buick Special-front end rear end?? mbjeep Suspension - Brakes - Steering 8 12-06-2009 06:32 PM
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 07:46 PM
front end tilt using my all steel front end old c10 head Body - Exterior 5 05-02-2003 01:45 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
