f100 brakes!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2011, 10:09 PM
f100 brakes!!
i have a 1979 f100 ford pickup. its got a 300 straight six motor in it 3 on the tree manual transmission. what i really wish it had was power brakes im getting sick of pumping them all the time.. what i was wondering if i could put a brake booster on it without any modification?
Old 11-17-2011, 10:34 AM
S10xGN's Avatar
Gotta love a turbo!
Shouldn't be needing to "pump the brakes", you have other problems...
Russ
Old 11-17-2011, 06:49 PM
i dont have to pump the brakes you have to pump them to build better pressure to stop better
Old 11-18-2011, 10:38 AM
S10xGN's Avatar
Gotta love a turbo!
Then I guess I'm not understanding what you meant in your first post...
Russ
Old 11-19-2011, 07:12 PM
is it hard to put a booster on that sort of truck
Old 11-20-2011, 11:16 AM
S10xGN's Avatar
Gotta love a turbo!
What I'm saying is, there is something wrong with the brakes you have now if you have to "pump" the pedal in order to stop. Fix that problem and you'll likely be satisfied with what you already have. Adding a power system to faulty brakes will not have the effect you are looking for...
Russ
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 07:52 PM
F100 truck brakes bighotroddin Suspension - Brakes - Steering 5 06-28-2010 12:36 PM
1969 f100 disc brakes one_am Suspension - Brakes - Steering 3 08-28-2008 09:53 AM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 03:07 PM
disc brakes on a '63 f100 bigblock454camaro Suspension - Brakes - Steering 4 09-15-2006 11:40 PM
