F100 suspension compatibility Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2012, 05:55 PM
I searched a bit and think I got my answer but I just wanted to make sure, I have a 68 F100 2wd and it has drum brakes all around. My question is can I put the front suspension from a 76 F100 on it? They are both twin I-Beam, but the 76 has ball joints and disc brakes, I can get the whole donor front suspension for pretty cheap just trying to make sure before I buy it.
Old 10-08-2012, 06:52 PM
Wiki Edits: 31
I'm 90% sure the frames are the same, so you just need the beams, and spindles/ associated hardware and bolt it up
Old 10-09-2012, 12:55 PM
Thank you, I went to the Pick-n-pull this morning and removed the entire front suspension from a 78 F100, the twin I-beams seem identical to our original ones, we got everything springs and brackets included but we are probably just going to swap the I beams as this seems to be the easiest route, if we cant just get the kingpins out to swap hubs.
I'll post pics
56 f100 suspension not low enough bigalow Suspension - Brakes - Steering 5 10-14-2011 07:08 AM
59 F100 front suspension Stangsbs5150 Suspension - Brakes - Steering 2 06-23-2009 03:15 PM
paint compatibility question it8eazy Body - Exterior 8 06-25-2008 02:30 PM
1977 Ford F100 Suspension, Lowering, Steering sbilbrey Suspension - Brakes - Steering 9 03-08-2008 11:10 PM
F100 Suspension Question smoke_eater Suspension - Brakes - Steering 1 10-22-2006 02:06 PM
