F100 Suspension Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 07:15 AM
smoke_eater's Avatar
I gotta 1955 F100 with a Gibbons/Cordoba front suspension under the front. My question is if anyone other that Fatman Fab sells drop spindles for it? They are charging damn near $500 for them. Id like to get them so I can properly lower this thing instead of just letting down the torsion bars. My other question is if anyone is running this set up, Id like to see some pics of the steering set-up. Thanks let me know if you can help.
Old 10-22-2006, 02:06 PM
i have a volare under a64 f100/same problem no suspension travel when at lower-look good ride height.i cut back rubber bump stops-helps. i halve a manual box-p.s. box weights about 50 lbs.-use box out of a 72 charger-used 2 u-joints from a escort and shaft-used tilt column from 76 ford ltd -filled in switch on column-used sealed bearing bottom of column-made strap to mount bottom of column to cab-used turn signals. i need a quicker steering box-flaming river box $420-any help ?
1977 Ford F100 Suspension, Lowering, Steering sbilbrey Suspension - Brakes - Steering 9 03-08-2008 11:10 PM
bumpsteer / suspension design question lowROLLERchevy Suspension - Brakes - Steering 2 08-30-2006 03:04 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
4-link suspension question brainsboy Suspension - Brakes - Steering 29 05-13-2004 06:39 AM
Hotrodders Guidelines -- READ ME Jon Electrical 0 06-14-2003 05:01 PM
