F150 issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2009, 05:12 PM
F150 issues
Need Help. I have a 06 F150 4wd. When I drive down the road there is an intermittent rattle that is coming from the front / mid point of the truck. When I put it in 4wd the rattle goes away. (I have electric shift on the fly) The handling of the truck is not affected and the wheel bearings are good. Can anyone give me advice as to what it can be?
Old 06-28-2009, 05:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Are you 100% sure its in the front? Cole
Old 06-28-2009, 05:26 PM
Yes. Sound like it could be coming from the differential area but I don't think it is the diff.
Old 06-28-2009, 05:29 PM
eloc431962's Avatar
Wiki Edits: 37
The reason i ask is i to have a 06 f150 4x4 had the same problem midway of my truck, turn the air on mine would rattle also,at first i thought it was the heat shield but it turned out i had to change the cats fixed it. Had bad cats on it from the factory, another thing that caused me problems was the bed shake does your do that also? Cole
Old 06-28-2009, 05:33 PM
I have been under the truck and there are no lose parts it has to be something internal>
Old 06-28-2009, 05:35 PM
eloc431962's Avatar
Wiki Edits: 37
Thats just it i went all over my truck could not find it, couldnt tell if anything was loose so i took it to ford put it on a rack found it. Cole
Old 06-28-2009, 05:47 PM
I might have to do the same.
Old 06-28-2009, 05:51 PM
eloc431962's Avatar
Wiki Edits: 37
Yea might come to that, about the bed if does shake while driving you can see it through the driver mirror it will vibrate if it does ford make a counter weight they can bolt in on the driver side of the frame at the rear of the truck it will help alot also. just trying to help. Cole
Old 06-28-2009, 06:00 PM
the truck is real solid the bed doesn't vibrate. I was thinking it was coming from the transfer case or the front axles. It like a lose part getting knocked around. But everything works and sound goes away when I put it in 4wd.
Old 06-28-2009, 06:02 PM
eloc431962's Avatar
Wiki Edits: 37
I would almost bet its the converters,how many miles is on the truck . Sounds just like the same thing mine was doing. Cole
Old 06-28-2009, 06:03 PM
just over 60k
Old 06-28-2009, 06:05 PM
eloc431962's Avatar
Wiki Edits: 37
Yea i would put it on a rack and have someone get in put it in gear and slowly raise the throttle until in makes the sound, while someone is listening and looking for it.Then you should find it . it would be nice if the rack was one you pull on where the wheels are like on the rack like a muffler rack or something like that. Hope al this helps you out. Cole
Old 06-28-2009, 06:07 PM
Yeah I think I will do that.
Old 06-28-2009, 06:54 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
If the cats are coming apart on the inside just tap them with a deadblow or your fist pretty hard and listen. That is the easiest way to find out.
Old 06-28-2009, 07:02 PM
I have had cats break apart before I don't think its the cats. This problem just started and the noise is loud. Cat will break apart gradually unless the motor back fires or is dumping raw fuel into the exhaust and then it ignites.
f150 drop question.. Blackhauk90 Suspension - Brakes - Steering 8 05-15-2007 10:44 PM
1986 F150 XLT Lariat 65Stanger Engine 8 03-10-2007 06:04 AM
Timing advance issues... autonuerotic Engine 27 11-22-2006 06:51 PM
Lowering - Camber issues 49lincoln Suspension - Brakes - Steering 1 05-25-2006 12:24 AM
