We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 07-31-2003, 08:50 PM
jamielanari jamielanari is offline
F250
I have a 1970 F250. I have 2 inch brakes . Can I simply convert to 2 1/2 drums by simply bolting on new drums or do I need new spindles? Or even better yet, what do I need to do to convert the front drums to disc?
Thanks......
Old 07-31-2003, 10:30 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
if this is a dual I beam front end, I've swapped out the complete front end from a disc brake 78 into my 66 1/2 ton. use the 78 master and prop valve, worked good.
crazy larry's Avatar
crazy larry crazy larry is offline
if i'm not mistaken, LMC Truck has a disc conversion, they have a free catalog, if you don't already have one....
as far as how to swap to 2.5" drums, i wouldn't waste the time to do that, waste it converting to disc instead, money better well spent.......
Old 07-31-2003, 11:58 PM
Red Rover's Avatar
Red Rover Red Rover is offline
New Member
I've been thinking...
... about doing a conversion kit too, but the cost may be prohibitive.
A friend did suggest finding a "rolled/wrecked" truck w/ disk brakes, and Twin I-beam axel suspension.
What years of Ford trucks would have what I need?
(modern disk brakes, not the early ones)
Thanks
Old 08-01-2003, 05:39 PM
F250 brake conversion
Thanks for the info!!!!!!!!!! I do have the latest LMC catalog and they do not have a conversion kit, to bad. Can you give me a list of parts that I might need for the disc conversion?
Thanks.......
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
