F250 brake and steering problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2006, 11:27 AM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
say you drive a 99 F250 diesel and you decide to go off road and you bottom out kinda hard. you get out of you truck and see that the trans cooler had a busted line and then when you drive your truck back home you realize that you no longer have power steering or brakes. the belt is still on. WHAT COULD IT BE.
ps this is a friends of mine of course, i would be this dumb
Old 07-23-2006, 09:39 AM
The Maintenance Geek
It wasn't...
a trans cooler...
It was the Powersteering/Hydro assist cooler...
K
Old 07-23-2006, 10:31 AM
53LEDSLED's Avatar
here to learn
it looks like trans fluid. i didnt know they had a cooling unit for steering or brakes ill go and check it out.
Old 07-24-2006, 10:24 AM
53LEDSLED's Avatar
here to learn
definitely not a "Power steering/Hydro assist cooler" im sure its some stupid plug of relay that hot disconnected. anyone know where to look. Ive already checked all the fuses.
Old 07-24-2006, 11:11 AM
aka Duke of URL
...you decide to go off road and you bottom out kinda hard. you get out of you truck and see that the trans cooler had a busted line and then when you drive your truck back home...
If you had a broken TRANS cooling line, it would never had made it back home. Did you check the P/S FLUID RESERVOIR?
I am not sure if these had HYDRO-BOOST or not (and too lazy to check). Anyone?
Old 07-24-2006, 02:26 PM
53LEDSLED's Avatar
here to learn
i was about 1/4 mile away from home. and yes it does have a hydro-booster.
Old 07-29-2006, 03:56 PM
53LEDSLED's Avatar
here to learn
Originally Posted by bates_k
a trans cooler...
K
you were right. i fixed the leek and added some fluid but i still dont have any PS or PB. im going to see if i can find anything that looks like its disconnected or broken.
Old 07-29-2006, 04:17 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Many people use trans fluid in their power steering pumps. It is possibly the truck in question has tranny fluid in its PS system. In fact in the past some manufacturers recommended using tranny fluid on the PS pump caps. I had an old Isuzu that had this recommendation on both the pump and in the service manual.
Old 07-29-2006, 05:09 PM
53LEDSLED's Avatar
here to learn
is it OK to mix them
Old 08-03-2006, 09:16 PM
53LEDSLED's Avatar
here to learn
just to let everyone know what happened; apparently enough fluid leaked out of the pump that it broke. i replaced the pump and everything is OK again.
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
disk brake and power steering conversion 54chevytruck Suspension - Brakes - Steering 3 03-13-2006 08:09 PM
Disk brake caliper & steering arm hitting gator412 Suspension - Brakes - Steering 3 05-28-2005 11:31 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
brakes, steering problem? not sure 89ford_pontiacman Suspension - Brakes - Steering 5 12-09-2002 10:20 AM
