F350 Hydroboost - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2009, 12:34 PM
F350 Hydroboost
Looking for some comments on my brake setup (well potential brake setup).
-Front Calipers are 2.8 inch bore (6.15 sq inch) GM Camaro on 11" rotors
-Rear brakes are Ford Explorer disk with 1.7 inch bore (2.35 sq inch) and have the drum style parking brake.
-Master cylinder is 1 3/8" from 2006 F250.
-Hydroboost is from same 2006 F250.
MC and HB are mounted on frame rail with 2 2lb residual valves and a propotional valve going to the rear brakes.
The front-rear caliper bore ratio is 38%.
Im wondering if the MC bore is too large. I suspect the HB should provide good boost with a range of pedal ratios, however at 1 3/8 should the HB fail, I will need at least ?:1 to provide enough manual stopping power.
Anyone have any experience with a similar setup?
99 chevy hydroboost problems dhspyder Suspension - Brakes - Steering 1 11-20-2009 07:59 PM
hydroboost bypass OUTLAW00 Suspension - Brakes - Steering 8 10-10-2008 11:15 PM
Custom Hydroboost on '69 Torino blacksunshine Suspension - Brakes - Steering 8 08-03-2007 10:44 AM
More hydroboost questions!? 69ChevelleAddict Suspension - Brakes - Steering 8 07-16-2006 07:55 PM
GM Hydroboost Blazin72 Suspension - Brakes - Steering 4 09-15-2005 10:17 AM
