-   -   Fabbing a Svo turbo to a 350? (http://www.hotrodders.com/forum/fabbing-svo-turbo-350-a-28153.html)
Rubberman2003 11-17-2003 10:54 PM
Can i take a turbo from an old SVO mustang and make it work on my camaro? if so what would i have to do? any websites or ideas would be great. Thanks
Rubberman2003 11-18-2003 12:20 AM
any idea how long this would take or how much it would cost? Mind you i alread have the turbo.
Mr. Green 11-18-2003 09:01 AM
here is a good site check it out:cool:
NorthStar 11-18-2003 09:21 AM
Its way too small.
4 Jaw Chuck 11-18-2003 12:08 PM
You would need two Rub.;)
Rubberman2003 11-18-2003 01:04 PM
what about one from a svo mustang (the one i have) and one from a Turbo T-bird??
I just talked to Turbo S10 and he gave me some pointers. I can get another T3 turbo pretty easy.
NorthStar 11-18-2003 01:56 PM
Nope. Not all 2.3 turbos are the same. Theres different exhaust housings and two different turbos.
.48 and .63 exh housings
IHI and garret turbos
Two turbos will work but you have to make sure theyre the same.
V8 S-10 11-18-2003 03:28 PM
A guy on our forum put a Turbo off of a 7.3 diesel on his 350.
TurboS10 11-18-2003 03:44 PM
For a single the old Ford T4 will work for about 450 HP. The TP-38 used from 97ish to 99 is good for about 500-550 and the 99-02 GTP38 is good for about 550 HP as well. Has been done several times with good results.
Like stated, the T3's need to match on the turbine to make sure EG pressure stays constant on both banks. Tuning will be inpossible otherwise.
I have seen a 350 with one of the .63 T3s on it. It was in a van, and was just used for low rpm grunt. Remember the 60 trim T3 is good for 325 HP. It would probably make around 500 lb/ft of torque at 3000 RPM as well, so it would be a real stump puller with spool up instantaniously. Mighty be cool for a off roader or something, but on a street car it would be real restrictive.
Chris
