Fabbing a Svo turbo to a 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2003, 09:54 PM
Rubberman2003's Avatar
Can i take a turbo from an old SVO mustang and make it work on my camaro? if so what would i have to do? any websites or ideas would be great. Thanks
Old 11-17-2003, 11:20 PM
any idea how long this would take or how much it would cost? Mind you i alread have the turbo.
Old 11-18-2003, 08:01 AM
here is a good site check it out
Old 11-18-2003, 08:21 AM
NorthStar's Avatar
Its way too small.
Old 11-18-2003, 11:08 AM
4 Jaw Chuck's Avatar
You would need two Rub.
— Han Solo
Old 11-18-2003, 12:04 PM
what about one from a svo mustang (the one i have) and one from a Turbo T-bird??
I just talked to Turbo S10 and he gave me some pointers. I can get another T3 turbo pretty easy.
Old 11-18-2003, 12:56 PM
NorthStar's Avatar
Nope. Not all 2.3 turbos are the same. Theres different exhaust housings and two different turbos.
.48 and .63 exh housings
IHI and garret turbos
Two turbos will work but you have to make sure theyre the same.
Old 11-18-2003, 02:28 PM
V8 S-10's Avatar
v8s10.org
A guy on our forum put a Turbo off of a 7.3 diesel on his 350.
Old 11-18-2003, 02:44 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
For a single the old Ford T4 will work for about 450 HP. The TP-38 used from 97ish to 99 is good for about 500-550 and the 99-02 GTP38 is good for about 550 HP as well. Has been done several times with good results.
Like stated, the T3's need to match on the turbine to make sure EG pressure stays constant on both banks. Tuning will be inpossible otherwise.
I have seen a 350 with one of the .63 T3s on it. It was in a van, and was just used for low rpm grunt. Remember the 60 trim T3 is good for 325 HP. It would probably make around 500 lb/ft of torque at 3000 RPM as well, so it would be a real stump puller with spool up instantaniously. Mighty be cool for a off roader or something, but on a street car it would be real restrictive.
Chris
