Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabric Covered Window Molding Tutorial
Old 09-02-2008, 11:37 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is online now
Wiki Edits: 22
After you're completely done, lightly clean the surface with mineral spirits, which is the solvent for this particular contact adhesive. That's all there is to it. Work slowly, take your time, be patient and you can do this no problem. Here's the finished door window molding. You can see where all of the mounting screws go because I pushed in on the fabric in those places to make it easier to locate the screw holes. Now I just have to do the other seven moldings.
ID:	32239   Click image for larger version
