Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabric Covered Window Molding Tutorial
Old 03-12-2009, 03:36 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is online now
Wiki Edits: 22
Once the fabric was attached to the inside of the molding frame, I could finish gluing the vinyl on the back of the molding just like I did with all the other moldings in this tutorial. Here are the finished moldings.
This was not an easy job, and I would caution you to think twice about trying something like this on your own if it's the first moldings you are attempting. You will get glue all over the fabric, but don't worry, it will come off easily with mineral spirits. Wipe the glue off as soon as possible, it's a lot harder to remove after it has completely dried and cured for a while.
ID:	36852   Click image for larger version
ID:	36853   Click image for larger version
ID:	36854   Click image for larger version
ID:	36855   Click image for larger version
