Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricate thick Header adaptor flange gasket
Old 05-18-2009, 11:02 AM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by 001mustang
My 351W SBF World Product Heads have square exhaust ports. My Hedman 88650 headers have oval ports that are too long and overextend the square head exhaust port flange area about 1/16". Since the header oval port is too big the header gaskets fail in short order (make a ticking sound). I am wondering if I can fabricate a header adapter gasket from 1/8" - 1/4" metal plate to properly mate the square head exhaust ports to the oval header ports?
Yes, done all the time. You'll probably need 1/4, I don't even know why I said "probably" just use 1/4 or 3/8s. I'd use aluminum plate, it's a lot easier to work. Can be built with hand tools if you take a little time to watch your dimensions.
Somebody like KOOKs probably makes them for a Ford but they won't be cheap.
Bogie
