Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricate thick Header adaptor flange gasket
Old 05-19-2009, 08:45 AM
001mustang's Avatar
001mustang 001mustang is offline
1/4" Aluminium Header Gasket DIY
Thanks 2 all.
I plan to fabricate a DIY header flange gasket from 1/4" Aluminium bar stock.
I bronze welded a layer of bronze on the primary tube mating surfaces then flat board sanded the bronze down to 180 grit.
I wonder if I should use paper gaskets or no gaskets on both sides of the DIY 1/4" Aluminium gasket?
Name:	6 0501092203.jpg
ID:	38394   Click image for larger version
Name:	7 0501092110.jpg
