Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating Aluminum Intake Manifold, need help
Old 12-30-2012, 03:27 PM
ryankalel ryankalel is offline
Originally Posted by techinspector1 View Post
In my opinion, tuned port, pressure waves and runner size can be tossed out the window when you go from naturally-aspirated to turbocharger-aspirated. All you will need is a plan to deliver the proper air/fuel ratio to the motor and a way to keep the charge cool. In your case, using FI simplifies keeping the A/F ratio in line. I like your "over the top" runners, same as the intake system on my old '91 Ford 300 six cylinder motor, but I think if I were doing it, I would fabricate an intercooler to fit in that space also.
That is what I needed to hear, I did not think that the pressure waves, length, etc, etc held that much importance when going to forced induction.
My CR is going to be right around 9:1, with a turbo I know that is higher than recommended. Can I place knock sensors on the engine to prevent detonation? If so, where on a loud and noisy 4 cylinder would be the best place?
Thanks
