Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating Aluminum Intake Manifold, need help
Old 12-31-2012, 11:46 AM
ryankalel ryankalel is offline
Originally Posted by hcompton View Post
I would copy the stock intake out of larger 1/4 thick wall alumiunum tubing.
Do you mean copy the inside diameter of the stock intake manifold? The original engine size is 2.0, I am stroking it to a 2.3. Will this make a difference in tubing size? I was thinking that 1/8th of an inch for the intake runners would be thick enough?? No?
I am also planning on reinforcing the runners by welding some 1/8th inch between the runners, like webbing. The flange I agree needs to be at least 3/8 inch.
Inside the intake/plenum should I run air horns or just smooth it down with the same idea of the air horn?
Thanks again for the input!!
