fabricating fender skirts - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2005, 01:21 PM
hi i wanted to fabricate some fender skirts for my dodge. does anyone have a how to or a web site that does? i would like to make them not buy them. thanx
Old 06-29-2005, 05:23 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
what model is it? i have skirts for my car and they're pretty basic. just find the right shape and you'll probably want to fold over each side for strength. maybe you could make a channel or something to run along the back for more rigidity. my skirts also have a rubber strip around it to protect the fender line. i think the tricky part to this would be figuring out an easy but strong way to fasten the skirt to the body. my skirts have a lever that kind of feeds up thru the fender line and then clamps the two pieces together and then latches on the inside of the skirt.
good luck.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 06-29-2005, 06:39 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Metal Fabrication
Several of the guys here also hang out over at www.metalmeet.com All they do over there is make stuff from metal..They would be a good bunch to talk to about your metal fabbing questions..
Not to take away from what is done here but those guys are specialists..
OMT
Old 06-30-2005, 02:08 AM
what i was going to start with is the old wheel molding. i was going to cut the chrome part off and use the fastener part as my starting point. sinse it is shaped just like the fender well and its already got the hole pattern for easy attachment. ive got a couple of ideas on how to make the the body part. i was thinking of welding a piece of sheetmetal to old molding piece and grind and bondo it smooth. wat u think? is there something else i should do, like for strenghth or something. thanx for replying and for future help i am given.
Fender Skirts RJB Body - Exterior 3 12-31-2003 07:28 PM
69-70 Chevy fender skirts still looking? Gearhead70Chevy Body - Exterior 3 12-30-2003 06:56 PM
Fender skirts spookabilly Body - Exterior 6 09-30-2003 05:53 PM
Help!...Need to ID these fender skirts mstngjoe Body - Exterior 5 01-16-2003 02:36 PM
12"X60" CRUISER FENDER SKIRTS WANTED KUSTOMRYDER Body - Exterior 0 03-15-2002 06:19 PM
