Fabricating a Fiberglass Hood scoop? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2009, 03:56 PM
ghormss1969's Avatar
I have a 1965 mustang that I would like to put a shelby gt 350 style hood scoop on. I've been wanting to fabricate something out of fiberglass for a while and i think that the gt 350 hood scoop design seems pretty straightforward. Any idea where i can find dimensions on it? Also what are a few pointers for fabbing something like this up for the first time?
Old 10-27-2009, 05:24 PM
milo's Avatar
point on positive
Did you know you could form your plug or mold with potters clay and then simply cover in fiberglass cloth soaked in resin.
Use a epoxy resin so you can add to your project when adjustments are needed. Regular resin won't stick to regular resin after it is cured...
clicky--> http://www.amazon.com/Mexican-Potter...ef=pd_sim_hg_2
keep it under a wet towel so it doesn't dry out till your happy
Old 10-28-2009, 07:18 AM
Trique Manufacturing
You can also shape your plug out of hard foam and coat it prior to laying your glass down. Once it is cured you just rinse the foam with gas. This is not your best choice though for a quality piece. The clay would probably work real nicely if you take the time and get it smooth. Milo, would you need to use a mold release agent on your clay plug?
aligning hood gto_ron Body - Exterior 8 03-25-2009 06:22 PM
how can I fix my hood scoop mess? bigwildgrin Body - Exterior 6 11-21-2006 10:05 AM
making a fiberglass replica of a metal hood. Dubz Body - Exterior 1 06-28-2005 05:10 AM
welding a metal cowl hood scoop to a metal hood? project66 Body - Exterior 7 11-10-2004 10:25 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 01:43 AM
