Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating a tranny cross member....
Old 01-24-2013, 06:41 PM
31ROC's Avatar
31ROC 31ROC is offline
So, as I approach getting this clutch set, bell, and new Muncie ready to install, I'm going to have to make a crossmember to fit...(31 Model A frame), the existing crossmember which held the 700R4 in place wont work...so I'm looking for pictures/ideas for a new one. Would like to bolt it to the frame for easy access of tranny removal if needed....can I bolt a square tube member to the BOTTOM of the frame rails? Or would that not be strong? (old cross member was bolted, but to the inside sides of the rails....
Thanks in advance....
