Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating a tranny cross member....
Old 01-24-2013, 08:02 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
This isn't on a Model a..But a few I have made that might give you some ideas..If your going to bolt through a tubing you will need to weld in some little pipes spacer's for the bolts to go through,, If you just bolt through the tubing,, They will just crush the tubing and will keep getting loose over time..
ID:	70843   Click image for larger version
ID:	70844   Click image for larger version
ID:	70845   Click image for larger version
