Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating a tranny cross member....
Old 01-25-2013, 03:24 AM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by NEW INTERIORS View Post
This isn't on a Model a..But a few I have made that might give you some ideas..If your going to bolt through a tubing you will need to weld in some little pipes spacer's for the bolts to go through,, If you just bolt through the tubing,, They will just crush the tubing and will keep getting loose over time..
those look great, but they all bolt to inside of frame rails, is it a "no-no" to bolt to the bottom of the rails?
