Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating a tranny cross member....
Old 01-25-2013, 07:11 AM
NEW INTERIORS's Avatar
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Originally Posted by 31ROC View Post
those look great, but they all bolt to inside of frame rails, is it a "no-no" to bolt to the bottom of the rails?
Many was bolted to that bottom lip before.. Just make sure you bottom lip is not rusted out any where's.. You can even weld in a thicker plate on the top side of the bottom lip if that will make you feel better... You can also drill and tap that plate before you weld it in,,, Then you won't need any nut's behind it..
