Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fabricating a tranny cross member....
Old 01-25-2013, 10:33 AM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by NEW INTERIORS View Post
Many was bolted to that bottom lip before.. Just make sure you bottom lip is not rusted out any where's.. You can even weld in a thicker plate on the top side of the bottom lip if that will make you feel better... You can also drill and tap that plate before you weld it in,,, Then you won't need any nut's behind it..
LOL...frame is new, better not be any rust!
Thanks for the input!
