Fabricating a tranny cross member.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2013, 06:41 PM
31ROC's Avatar
So, as I approach getting this clutch set, bell, and new Muncie ready to install, I'm going to have to make a crossmember to fit...(31 Model A frame), the existing crossmember which held the 700R4 in place wont work...so I'm looking for pictures/ideas for a new one. Would like to bolt it to the frame for easy access of tranny removal if needed....can I bolt a square tube member to the BOTTOM of the frame rails? Or would that not be strong? (old cross member was bolted, but to the inside sides of the rails....
Thanks in advance....
Old 01-24-2013, 07:02 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
This isn't on a Model a..But a few I have made that might give you some ideas..If your going to bolt through a tubing you will need to weld in some little pipes spacer's for the bolts to go through,, If you just bolt through the tubing,, They will just crush the tubing and will keep getting loose over time..
ID:	70843   Click image for larger version
ID:	70844   Click image for larger version
ID:	70845   Click image for larger version
Old 01-25-2013, 02:24 AM
killeratrod's Avatar
not to hijack the thread. But NEW INTERIORS You do some killer work, Those beads look as if a robot did them Perfect.
Old 01-25-2013, 03:24 AM
31ROC's Avatar
those look great, but they all bolt to inside of frame rails, is it a "no-no" to bolt to the bottom of the rails?
Old 01-25-2013, 03:40 AM
not one is bolted to the bottom rail.
Old 01-25-2013, 03:50 AM
here you are ready to install a new clutch & Trans & make your own cross member, But in one of your other posts you need to know how to install a simple oil pan & gasket. What gives?
Old 01-25-2013, 04:10 AM
31ROC's Avatar
thats incorrect....I asked about installing a chrome pan, and wanted to know best gasket & sealant to use....its been about 25 years since I've worked on my cars, just need to get the dust out....the cross memeber will b no sweat to make, as I work for a metal fab shop, but wnated to see if anyone attached them to bottom of rails, as I am cramped for space on insides.....
Old 01-25-2013, 07:06 AM
Thanks... Killer ... I was that Robot for many years...
Old 01-25-2013, 07:11 AM
Many was bolted to that bottom lip before.. Just make sure you bottom lip is not rusted out any where's.. You can even weld in a thicker plate on the top side of the bottom lip if that will make you feel better... You can also drill and tap that plate before you weld it in,,, Then you won't need any nut's behind it..
Old 01-25-2013, 07:16 AM
Look at the first picture,, Think of that angle iron being the bottom lip in your car.. You can do something like that one...That car had a big block in it with a lot of HP.. didn't break anything but the tires..
If you do it this way,, Try to make it sit on the top of the bottom lip.. Then your bolt's are just holding it in place..
Old 01-25-2013, 10:33 AM
31ROC's Avatar
LOL...frame is new, better not be any rust!
Thanks for the input!
Old 01-25-2013, 10:43 AM
LOL... That's what's bad about the web,, You have no idea what someone is working with....LOL.. You should be OK then..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Trophyman (02-06-2013)
Old 02-06-2013, 11:15 AM
Last journal entry: 1939 Chevy Master Deluxe New Project(3)
Timely thread since I'm looking at building a trans mount right now. Again, don't want to hijack this thread but what size tubbing would be sufficient giving the car is a driver and won't be thrashed. SBC/4L80.
Old 02-06-2013, 06:06 PM
31ROC's Avatar
I have no idea, (I think you are refering to "tubing"?) I have not started mine yet....but the crossmember I took off was about 1 1/4 tubing....if you look for crossmembers at the big website suppliers, ie: Speedwaymotors.com, I believe they'll indicate what size they are. Should give you a good idea. I personaly am planning to make this new one out of square tubing....
The Following 2 Users Say Thank You to 31ROC For This Useful Post:
41 kustom (02-06-2013), Trophyman (02-08-2013)
cross member redneck25252000 General Rodding Tech 0 11-18-2009 03:58 PM
Tranny to cross member alignment issue Blue67Camaro Transmission - Rearend 5 01-14-2008 01:24 PM
55 chevy cross member ???? tiresmoke55 Transmission - Rearend 9 04-15-2006 07:20 PM
Tranny mount and cross-member fbird Transmission - Rearend 0 07-18-2003 08:00 AM
Tranny line and rear cross member question. Bo_Jangles Transmission - Rearend 3 03-08-2002 08:18 AM
