Fabrication tool - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-05-2006, 03:37 PM
Last journal entry: 30 Ford sedan
helping hand
Thanks for the good words, we all can use help for time to time.
I have read many enterys from other that has been of interest to me.
Thanks to HBB for the service
  #17 (permalink)
Old 02-05-2006, 08:34 PM
If You Can Add One More Guy.....Would Be Highly Appreiciated!!!! rasdmt@sofast.net.... Kool Plans!!!! Thanx! Ron
  #18 (permalink)
Old 02-05-2006, 08:44 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Feel like sending out one more? I would appreciate it very much.
blb1408@hotmail.com
That is so cool. My dad works at a place with a CMC plasma table. I teach various CAD programs and we get into some CNC, but I have never seen this done.
Dad and I could build one for his workshop with these plans. He would love it.
  #19 (permalink)
Old 02-08-2006, 05:23 PM
Awsome
If the board gave awards for good thinkng... You would be the winner. It seems so obvious now that I see it. I can believe I have never seen one of these before. I am familiar with CNC machines with all the complicated stepper motors and thousand dollar software packages. I think I will give builing this try.
Thanks.
  #20 (permalink)
Old 02-10-2006, 10:41 PM
This is so cool.. thanks for posting your plans. I want to take the plastic gears out of my son's battery powered 4wheeler and make metal ones. This should help once I am able to build it.
  #21 (permalink)
Old 02-26-2006, 01:49 AM
Thank You Highly For Plans.....It Takes A Special Person! Rasford
  #22 (permalink)
Old 02-26-2006, 08:58 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Not free but here is another option from Steve Smith Autosports. Not only has a good flame cutting pantograph design, also has easy to make metal brake, hydraulic press (Harbor Freight press is dirt cheap and very good - probably isn't worth building your own), engine hoist (ditto the press comment), engine stand (ditto, ditto), and a chassis/body rotisserie design which is a popular question on this board. Also has some fabrication tips for the novice metal worker. Pretty good reference book, well worth the $20 tab.
  #23 (permalink)
Old 03-08-2006, 10:57 AM
I've got that book as well... well worth the $$$.
  #24 (permalink)
Old 03-08-2006, 11:13 AM
sbchevfreak's Avatar
Licenced Automotive Technician
If you don't mind one more, me too, please Tom. ngdoupe@sasktel.net
  #25 (permalink)
Old 03-11-2006, 03:10 PM
Chopt 48's Avatar
Thanks for telling us about the book Willys 36, It will be one more added to the library. Amazon.com shows some used ones but they are only a dollar off new.
  #26 (permalink)
Old 12-17-2010, 02:15 PM
Pantograph
Originally Posted by acourtjester
Attached is a picture of a flame pattern cutter I built years ago and was published in "The Home Shop Machinist" It will trace a wooden pattern manually and cut steel plate. I have cut brake brackets, motor mounts, axle brackets ect on it. I can supply you with plans for free!
Have fun
Tom
Tom,
If you still have these plans available I would like a set this is just way cool!
Thank you,
David
jayrak@altelco.net
Fabrication Tool Questions sifua Body - Exterior 15 08-15-2007 11:57 PM
push rod clearance tool lanierledford Engine 1 07-04-2005 08:32 PM
New Scan Tool user 36scsc Electrical 3 01-29-2005 07:35 PM
You're a Tool Box! Beenaway2long Hotrodders' Lounge 20 08-03-2004 06:05 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
