-   -   Factory alignment/weight change (http://www.hotrodders.com/forum/factory-alignment-weight-change-215637.html)
ganymede 02-28-2012 05:11 PM
I always wondered if alignment changes were to be made after removing weight off front end. For example my '72 Nova has an alum. pump, heads, intake, battery in trunk, etc. Typical hot rod stuff. That would scooch the tires in for more negative camber. Right? So do I re-align for factory or will the front end want a different solution? Factory camber for me is .25N to .75P. However I was wearing out new tires fast with .25N. I adjusted to 2p & no more wear. Weird I know.
firebird7980 02-28-2012 07:09 PM
Changing weight in front end does affect alignment angles. toe will wear tires fast the camber
