Factory alignment/weight change - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2012, 06:11 PM
Last journal entry: Photos
I always wondered if alignment changes were to be made after removing weight off front end. For example my '72 Nova has an alum. pump, heads, intake, battery in trunk, etc. Typical hot rod stuff. That would scooch the tires in for more negative camber. Right? So do I re-align for factory or will the front end want a different solution? Factory camber for me is .25N to .75P. However I was wearing out new tires fast with .25N. I adjusted to 2p & no more wear. Weird I know.
Old 02-28-2012, 08:09 PM
Changing weight in front end does affect alignment angles. toe will wear tires fast the camber
Winters Quick Change weight estimated? BigRoy1978 Transmission - Rearend 0 03-09-2011 11:19 PM
I want to put my car on a diet. Who has done this, starting weight? Ending weight? espo1980 Engine 21 08-03-2009 03:20 PM
70 chevelle factory weight and dimensions classic_chevy_guy Suspension - Brakes - Steering 7 07-08-2005 12:28 AM
GM HEI Spring/Weight Change!?!?! fireforsin Engine 2 09-24-2003 03:09 AM
Won't change,wont' chang,won't change Samrupert Transmission - Rearend 6 01-11-2003 02:32 PM
