Factory Hood Blanket/Insulation - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 07:34 AM
My GMC truck once had a factory insulation blanket on the underside of the hood, and it appeared to be fiberglass. When my son got it wet during a mudding session, it just slowly fell apart and came off the hood. I can buy a replacement hood blanket from LMC truck, but it would have the same limits as the old one (it might fall apart again).
Is there another material that would work better, and hold up well under the hood? The hood is pre-punched for flat plastic retainers that hold the insulation, so I don't have to use adhesive to keep it on unless it would work better. I would like to find something that comes in one large piece, big enough to cover the hood, and that I could buy locally. I am mostly interested in engine noise control, not insulating the hood from heat.
Thanks,
Bruce
Old 01-31-2010, 11:23 AM
SSedan64's Avatar
There's the large rolls of foam insulation with foil on one side and self adhesive backing, peel & stick. Come in many thicknesses.
Old 01-31-2010, 12:14 PM
I may try the foil insulation blanket, since its easy to buy at the local home stores. However, I would think that the foil surface would reflect noise, and may not provide as much sound control.
I'm running an SBC with severe duty thermal fan clutch, low gears (4.10) and no overdrive (TH350) which means engine noise from moving parts at 60-65 MPH is fairly high. If I didn't have a tach to verify that I'm only at about 2800-3000 RPM, the sound would make me think I am over-reving the engine.
Thanks,
Bruce
Old 02-02-2010, 08:24 PM
Kevin45's Avatar
Just one of the guys
The LMC hood insulation would work fine. Just try to keep water off of it. By that I mean don't hit it with the wand at the car wash or turn the hose directly on it. They seen to have some kind of a coating that helps to repel the water somewhat. They will stain over time but will not deteriorate unless you poke holes or damage it with the car wash wand. I've replaced a few using LMC. Also when you order them (if you do) make sure you order the plastic clips that hold them in. No more expensive than they are it's not worth it to try and save the old ones.
1951 chevy hood ? Area_51 Body - Exterior 6 02-15-2008 04:21 PM
'36 Ford hood hinge repair question flynbrian48 Body - Exterior 1 12-28-2007 04:22 PM
Making a 'glass hood S10xGN Body - Exterior 1 02-22-2006 12:42 PM
Removing "trim bump" ini 'glass fenders S10xGN Body - Exterior 12 01-31-2006 09:47 PM
1966 chevelle fiber glass hood replacement Ratt79 Body - Exterior 8 01-12-2006 04:08 PM
