Factory OEM parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2008, 05:31 AM
Factory OEM parts
Hey guys i'm in the process of restoring a 1982 Olds Cutlass Supreme. Only problem is i can't seem to find parts for it. I just know that if i didn't need them they would be right in my way, and now that i do thier nowhere to be found, but ain't that just the way it goes. If it was a snake it would probably bite me. I would preferre factory OEM parts but nice aftermarket stuff wouldn't be bad either. I basically need all new interior parts, dash, seats, headliner, ect. I would also like to find some aftermarket stuff to redo the engine compartment. The car origonally had A/C but i'm not gonna be puttin that back on so i'd like to find a panel to close up all the stuff that i removed but still keep the heater core and blower for a defroster. I've been lookin for a couple weeks now so any direction u guys can offer is much appreciated.
Thanks, Danny
Old 07-03-2008, 07:44 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Parts
Kinda general but as far s the fabric parts are concerned the material that is real close to original is available and a good sticher can come up with it..Some of the trim pieces were also used in other GM cars of that body style so they can be found at swap meets and such..Also get out and about to the local pick-a-part and watch e-bay and craigslist for similar types of parts cars..Probably the pieces will not be all found in a week or two and will need some searching around to locate what you need..If one is careful one can remove and restore the plastic pieces so they look good..
Most of us wind up in the do-it-yourself mode as not all of what we need is readily available and we have to do that in order to get what we need..
When you get a bit more specific let us know and maybe someone has a line on where things can be found..
That is a GM G body so other GM G body cars such as the Malibu and Monte Carlo share a lot of pieces so hse may be a source of some parts..
Good Luck
Sam
Old 07-03-2008, 08:14 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The problem you are facing is common. It's a matter of economics. In order for there to be a company or companies willing to provide replacement parts for your car, there has to be a market for those parts. An '82 Cutlass isn't exactly a classic, so finding parts will be very tough. Now if it was a '72 Cutlass you could find 10 places that offer parts. Fabric is available at Original Auto Interiors Good luck.
Old 07-03-2008, 08:29 AM
JrJohnston's Avatar
Thanks, Danny
Try posting over here in the parts wanted forum www.maliburacing.com
I know it says maliburacing,but there are alot of guy's over their with other G-Body GM's(MonteCarlo,Cutlass,GrandPrix.....),and if they don't have it forsale they can help you find it.I found a perfect set of rear wing window's for my 83 Malibu Wagon on there,after look every place else for a year for them.
You will have to join the forum.
Rock Auto Parts for Body Parts? 85GMCguy Body - Exterior 3 05-23-2014 04:47 PM
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
A friend's 96 F150 (302), factory speed parts ChevelleSS_LS6 Engine 5 04-12-2008 12:00 AM
1964 Muncie M-20 parts question 1964 Oldsmobile 442 Transmission - Rearend 3 04-10-2004 10:25 PM
Model A/Model T oem parts? Rhansen Hotrodders' Lounge 5 03-09-2004 09:07 PM
