Factory re manufactured transmission ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2007, 03:35 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Question Factory re manufactured transmission ID
Hey Y'all
Upon Removal of the Motor & trans In my Suburban I noticed a Raman sticker from GM
Am I right in saying this is a 700R4?
Is this heavier duty than the stock trans that would have been in there?
Any & all info is greatly appreciated
R
ID:	24965   Click image for larger version
ID:	24966   Click image for larger version
ID:	24967   Click image for larger version
"SlowRide66"
"Illegitimis non carborundum"
transmission fluid temperature nixwillys Transmission - Rearend 1 04-16-2006 01:03 PM
Transmission Stuck :( crusherdbuzz Transmission - Rearend 2 03-05-2006 03:00 PM
Trans cooler lines which is which atlantis Transmission - Rearend 44 01-08-2006 04:19 PM
How to disengage transmission from block? El Raton Transmission - Rearend 10 11-26-2005 07:55 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
