Failed calif smog.....Again - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2013, 11:27 PM
Damn Im getting tired of this crap. I try very hard to keep my vehicle running good and smog compliant. It is an 84 Blazer with a 350 with 5000 miles on it. Carb is a new edelbrock C.A.R.B. cert. It failed 2 weeks ago due to high hydrocarbons. Replaced plugs, wires reset the timing, oil is clean and the air filter is also clean.Again they are saying high hydrocarbons. Any ideas? It is not like I am driving a POS.
Old 02-01-2013, 11:42 PM
vinniekq2's Avatar
Cat,is it original?
Old 02-01-2013, 11:46 PM
vinniekq2's Avatar
CARQUEST/WALKER 15646 Catalytic Converter
MAREMONT ALPHA-NUMERIC 28738 Catalytic Converter-Drct Fit
ULTRA FIT EXHAUST CC1025
Old 02-02-2013, 12:48 AM
I believe the cat has been replaced, not sure when
Old 02-02-2013, 09:07 AM
LATECH's Avatar
I am with Vinnie. There should be practically no hydrocabons present , unless cat is no longer converting.
Fact is stranger than Fiction
Old 02-02-2013, 09:09 AM
Wiki Edits: 27
Rejet time ?
Did it fail at low or high speed test ? You might have to pay to have it worked on someone that will do a tune -test with it not hooked up to sacto computer. My 5.0 ford engine passed in Calif, Then when I was working in Utah, had to have it retested there . It failed low rpm test. 4000 ft elevation change it needed Carb tunning to match altitude change. . C. .a. r.b approved parts can still need work to get good numbers. The last Time I had my 5.0 Mustang smog tested in Calif, I wondered why It was taking so long. Then I saw the Tech sniffing my mustang while most of the hook ups were on something else. The mustang was putting out the good numbers he needed.
Old 02-02-2013, 10:08 PM
Actually got through today. I believe it was the high rpm hydros. The shop it does the testing for me is very accomadating. I have no idea how some of these poor people that can not afford new cars get through this. To me it is frustrating, to others it is a huge problem. The rolling exemption needs to come back
The Following User Says Thank You to benchracer1 For This Useful Post:
dinger (02-03-2013)
2001 toyota camry failed smog test AutoGear Engine 3 08-19-2011 10:26 AM
Newb from calif capjr Introduce Yourself 2 03-09-2010 05:29 PM
Calif. Registration Help 30 sportcoupe Hotrodders' Lounge 6 05-21-2006 08:19 AM
smog, smog, smog....CA smog , failed. jakeslim Engine 12 08-20-2005 11:59 AM
well i failed smog today. 73novasupersport Engine 4 08-01-2005 05:05 PM
