-   Hotrodders' Lounge (http://www.hotrodders.com/forum/hotrodders-lounge/)
-   -   Fair price? (http://www.hotrodders.com/forum/fair-price-226214.html)
Project89 11-17-2012 09:52 PM
Fair price?
im going to be pulling the engine out of my twin turbo iroc soon and will put it up for sale on my local forums problem is i dont know how much to ask
its a fresh sbc 355 about 500 miles on it
gm forged crank std/std
gm rods that have been resized shot peened strees relived with arp waveloc bolts
speed pro popup pistons 9.2-1 cr
summit 224/224 cam and edelbrock 234/244 cam edl currently installed
ported 882 heads , stainless valves
port matched tpi intake
i will also be in cluding the twin turbo headers but no turbos or wastegates.
along with that ill be selling ir without injectors
so basically a complete longblock and a set of twin turbo headers
i was thinking around 1,200 bucks sound fair? or is that to cheap/expensive for what it is
Project89 11-18-2012 12:41 AM
i guess i should have added its in a 0010 4 bolt block .030 over
gearheadslife 11-18-2012 05:26 AM
unless you plan on getting 300.oo I'd leave it in the car so the buyer can hear/see it running..
low miles or not.. if I can't see it run.. it's a core as far as paying money to buy it..
receipts for the parts/machine work will help..
1200.oo isn't out of line if you have proof of the work and parts..
but at 1200.oo I want to hear it run.. and be able to pull the pan and look at a main bearing..
good luck..
delawarebill 11-18-2012 07:57 AM
i kinda agree with gearhead
hearing it run is big... i'd never put that money into a motor i can't hear.. but if u want to pull the pan and ck the bearings???
U BETTER B BRING'N A PAN GASKET TOO... or no dice..
monster76 11-18-2012 08:00 AM
you can weld right? Just build a little stand out of steel so you can start it on the stand
Project89 11-18-2012 07:45 PM
thaks guys i put it up for sale now so potential buyers could hear it runin the car / go for a test drive if ti dosent sell before i pull it ill build a lil engine stand it can be run on.
only thing i dont have paper work for is the rods , but it is obvious if u pull the pan off
if the engine dont sell ill prolly drop it in my silverado 2500 with a milder cam
killeratrod 11-18-2012 08:55 PM
All the good stuff gone
Show someone it's running then take off all the good stuff $300 is more then fair!! my new 2 cents!!
