fairlane disk brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2008, 10:39 AM
is it possible to use ford ltd disk brakes for a front disk brake conversion on a 1965 ford fairlane? and is it possible to use the brake booster?
or would i have to invest in aftermarket parts? just looking for a cheap easy way to upgrade an old car
Old 02-20-2008, 10:47 AM
aka Duke of URL
The easiest/cheapest way to convert your car is with the GRANADA/MAVERICK swap. GOOGLE GRANADA DISC BRAKES and you will find all the info you need.
Old 02-20-2008, 11:22 AM
alright thanks i never thought of the grenada. i just assumed the lincoln/ltd.
but anyway now that i think of it i have another question,could i use the front suspension from a grenada/lincoln/other ford car?
Old 02-20-2008, 12:20 PM
aka Duke of URL
What is wrong with the present suspension?
Old 02-20-2008, 03:50 PM
31 five window
Last journal entry: grill and rear end
Put a mustang 2 under it. We put one under my daughters 66 mustang and it worked out great.Now we don't have those big shock towers and we have rack and pinion steering.It also gave us plenty of room for the tuned port 350 and 700R4.
Old 02-20-2008, 07:28 PM
theres nothing wrong with the suspension,i just want a more common set up.
are the mustang ll suspensions bolt in or is welding needed?
Old 02-20-2008, 07:33 PM
31 five window
I don't know if anyone makes a bolt in for that car. We cut ours out of a pinto and welded it in ourselves.It fit really well.
Disk Brake Conversion for 1947 Dodge 1/2 ton pickup front axle leonard egan Suspension - Brakes - Steering 4 01-21-2011 06:17 PM
disk brake and power steering conversion 54chevytruck Suspension - Brakes - Steering 3 03-13-2006 07:09 PM
early nova disk brake conversion hotrod66_57 Suspension - Brakes - Steering 2 04-29-2005 01:55 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
