Fairmont460/C6; tranny/8.8 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2010, 10:08 PM
Hello out there, I'm planning on putting on Edelbrock Alum. heads with 9.5 compr. and a good-sized cam for my 1977 460 eng. and I'm wondering what's the maximum gross/flywheel hp and tq you can have before you need to have a safety shield, upgraded flexplate, and things like c-clip eliminators and Moser axle shafts, etc. Thank-you
Old 01-01-2011, 09:53 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
what are you doing with the car? Drag strip , street only? If you are racing, a safety shield is a good idea at any HP
Moser axles if you are running drag slicks may be needed. Again it goes back to the power you have and it does not sound like much at this point
Old 01-01-2011, 09:57 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
are the 8.8 axles 29 or 31 spline ?
Old 01-01-2011, 11:50 AM
I will be taking the car to amateur night at the drags only 2 or 3 times a year, so it's mostly a street/hwy car. Right now, it has only 229hp at the wheels at 4,400rpm and 332tq at 3,200rpm. Of course, the C6 sucks alot of power. The local Ford racing/engine builder says he can give me a total of 450-500 gross hp for $4,000.00 with my stock iron heads, so I think I'll go without the alum heads. I have headers and a Edelbrock 750/Performer Intake, alum. rad/dual elect. fans and Mallory ignition/coil. If I don't use slicks, then I don't need to upgrade to Moser? Also, I'm thinking if I went to a 2.93 or 3 even ratio, I would spin the tires less, correct?
The axle is a 3.27 out of an '88 LX 5.0, don't know what inches the spline is.
Old 01-01-2011, 12:11 PM
& matts38chev
prob only 29 spline, so they may need upgraded if it gets to much bite at the track
94 s10 tranny questions 94chevys10_zr2 Transmission - Rearend 6 07-17-2009 12:27 PM
C-4 tranny to a 5.0 motor questions bob41 Transmission - Rearend 5 02-14-2006 08:36 PM
new tranny questions lightemup Transmission - Rearend 9 12-23-2004 09:55 AM
Tranny Questions 84montess Transmission - Rearend 2 08-20-2004 09:47 AM
Tranny Questions JRS1967 Transmission - Rearend 1 08-24-2003 12:01 AM
