Falcon Gas Guage - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2010, 12:50 PM
Falcon Gas Guage
I have checked all wiring, replaced tank,sender & constant volatage regulator. Guage will still not register. I checked guage with 3 volt battery and guage works correctly. The guage will register with the constant voltage regulator revoved from dash panel, not sure if registering correctly. I assume when regulator is attached to dash panel,it puts a ground on it! What can I check next. This is on a 1964 Falcon.
Old 03-31-2010, 02:51 PM
Joe G's Avatar
Registered user
Yup, to work correctly the regulator needs to find a path to ground through the instrument cluster or whatever it is mounted to. Make sure the dash panel is well grounded.
Gas Thieves!!!! Weimer Hotrodders' Lounge 28 03-03-2010 02:46 PM
Don't pump gas on May 15th fishjl Off-Topic 39 05-17-2007 05:16 PM
Got Heads! Unleaded gas problems? steveyb4342 Engine 25 05-08-2007 06:15 PM
Help Please? 87 Dodge mini-ram van - stalling if little gas applied jojo99 Engine 3 07-27-2005 06:19 PM
Gas Guage and Kill Switch question Bo_Jangles Electrical 9 05-01-2003 09:54 PM
