false guide replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2013, 10:17 PM
I have the equipment to install bronze guide liners and have done it for years with no problems. However, now I have a collection of heads that have had the orginal guides drilled out and replaced with thick walled false guides. Can I installed the guide liners in the false guides or should i buy the correct driver and installed thick wall false guides? Many sources say that installing thin wall liners is the prefered way for engines like BBC's so I don't see why it won't work in other engines.
Old 02-03-2013, 12:57 AM
BOBCRMAN@aol.com's Avatar
Should work great. The only problems I have with it is some random cracking at the seal area, if they are cut for .500" aftermkt seals. Most of this can be prevented by installing, broaching from the chamber side.
Old 02-03-2013, 01:25 AM
Yes, cracking the guide was one of my concerns. My other concern would be with spiral guides if the boring tool didn't cut deep enough to remove the spiral would this cause any problems?
valve guide replacement 2old2fast Engine 4 11-26-2011 09:29 PM
true or false Can drive 55 Transmission - Rearend 6 12-17-2005 08:40 PM
False advertising or not Centerline Hotrodders' Lounge 36 12-06-2005 09:01 PM
False advertising? lluciano77 Hotrodders' Lounge 11 10-16-2004 08:05 PM
