I have been using regular cheap box fans for 18 years . Put them in the garage windows to pull air out of the garage.
Use to put the cheap blue filters behind them , right in front of the motor. Have not done that in years. Start them before spraying and turn them off after completion. May not be the safest choice . |
I've been using the 1050cfm version of this fan with the optional variable speed control. TEFC motor.
http://www.greenhousemegastore.com/T...ctinfo/FA-VFT/ Depending on the size of area you are using, you probably wont need to run it at full speed. I ran at about 2/3rs speed in a 12x20 foot garage. Full speed will pass too much air across the painted surface, and in some cases drying too quick along with pulling any dirt into your fresh paint. I even ended up with a crude deflector to move the air differently. My (now disassembled) paint booth: ![]() The filter: ![]() And what isn't in my lungs - and with a low overspray gun: Dave W |
FWIW, just because no one has ever heard of a paint booth explosion is no reason to discount the possibility. Vince |
Thanks Vince - I had written a similar response about TEFC motors - and Earthlink went down just as I posted Dave W |
TEFC motors are not approved as explosion proof motors. Explosion proof motors are based on TEFC enclosures but they ahve to meet certain classifications in order to certified as such. Use of a basic TEFC motor in an exhaust fan does not meet explosion resistance guidelines for a combustible spray and the motor manufacturer is not allowed/or will not recommend a motor for an explosion proof motor, it is up to the end user to specify which motor. Check out Baldor.com for their explosion proof motors as standard items and what they are good for. I'm a Baldor distributor and have been down this road a few times with customers, it is frustrating as can be. An engineer from the customer usually gets involved in the XP motor selection and specification process.
What you are looking for is an explosion proof motor. Those are used where dust or fumes may ignite. I think that using an explosion proof motor would be overkill and you wouldn't like the price, either.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Sorry,......I posted before I read the post before mine. One of the he two factory schools I went to was the Baldor school, and cyclopsblown34 is right on the button.
I should clarify, I misspoke when I said the motor is "intrinsically safe". The proper definition of "Intrinsically Safe" is as follows.
In a potentially explosive atmosphere we need to not only worry about creating sparks, we also need to consider the surface temperature of any operating device. If a devices surface temperature exceeds the auto ignition point of the atmosphere it is being exposed to then the potential of an explosion is high. Vince Last edited by 302 Z28; 06-28-2010 at 05:12 PM. |
Here's a typical spray booth fan http://www.grainger.com/Grainger/items/7F927?Pid=search They use aluminum blades for spark resistance, and the TEFC motor is mounted out of the airstream. The belt is typically inside a steel tube running from the outer housing of the fan down to the shaft. They wouldn't pass muster as explosion proof, but they do have a sort of maze type path any spark from the motor would have to pass thru to get to the airstream.
Real no kiddin explosion proof components are more expensive than you even guess. Motors are bad enough, but motor starters in explosion proof enclosures will make the motors look cheap. A little section of flex conduit at the motor, made to comply with explosion proof requirements, can cost a few hundred bucks by itself. We used to do some work that required all explosion proof components, but it was at a site that did things like loading tracer rounds, making solid rocket fuels, etc. Because of the extreme cost, no one uses explosion proof stuff if there's any other possible way to get the job done safely. |
| New fan with adjustable temp control help | redride | Electrical | 3 | 05-30-2009 10:22 AM |
| building a fan shroud - need help | 32Tudor | Hotrodding Basics | 30 | 07-03-2008 09:01 PM |
| Correct size & type of radiator fan & clutch? | Steve S | Engine | 3 | 12-04-2006 10:29 AM |
| Electric cooling fan | Z-Money Pit | Engine | 1 | 08-29-2006 08:27 PM |
| Need advice on a good electric fan set up. | Streetmaster | Engine | 13 | 01-07-2006 02:37 PM |
