fan / alternator hp losses ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 06:44 PM
Interesting test, seems like a lot of hp losses for a conventional fan. Check it out
http://www.carnut.com/ramblin/dyno.html
Old 04-19-2010, 09:26 PM
ericnova72's Avatar
More for Less Racer
Doesn't surprise me in the least, the fan is the biggest hp draw of all the accessories. What cracks me up is the guys who won't run an alternator on their "race car" because the say it eats too much power . 1.28 hp on the test you linked, and I have seen the same result in other tests.
Old 04-20-2010, 09:39 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Really interesting.
Thanks for the link!
Old 04-21-2010, 03:32 AM
Good stuff.
They mentioned "design flaws and safety issues" with the flexfan. I can imagine that it's to do with the constant flexing and the fatigue it might cause, but does anyone have more details/experiences/horror stories?
Old 04-21-2010, 06:22 AM
my $.02:
VERY likely he has the decimal point in the wrong place for HP....
consider this ex:
746 watts = 1HP
typical oem 2k cfm plus 18" plastic blades electric fan operates with 14V x 20A =280 watts
280W/746W=.37HP to move 2k+ cfms of air...
(it does take "some" more power to spin a steel fan versus a plastic fan due to the steel mass/weight but it is typically/roughly .25HP depending on the fan and the pulley ratio)
AND his test has next to nothing to do with how a fan clutch actually does work in the real world...
random pick explaination:
http://bbs.zuwharrie.com/content?topic=12721.0;wap2
LOL,,,if the motor coolant temp is hot enough to actually lock up the fan clutch at 1600 or 4500 rpms,,,you won't be worrying about HP drain...
he didn't say what the pulley ratio was or rad core config but if you move the decimal point over one place those could be (????) legit numbers...
(yeah,,,,, a direct drive/no clutch BB 18" steel fan would/could pull about 4HP at 4500rpm's "but" there would also be a MAJOR hurricane's worth of air thru the rad and engine compartment to cool the motor!!!!)
Old 04-21-2010, 06:56 AM
You make many good points, but in the real world most fans are setting in the engine compartment just spinning thrashing air about. The builders won't build or have know idea how to build a good fan shroud. Also they do not want the bulk uglyness of a shroud with the bling/chrome pieces.
The good electrics have built in shrouds that provide a plentum so air will be drawn across the full face of the radiator.
Also seen many ten inch fans slapped on the radiator face with zip ties trying to cool a smallblock!
Any way you look at it a 40 Hp loss is too much to throw away or just write off as operating expense.
Old 04-21-2010, 08:41 AM
jag,
you missed my point?
doesn't matter what the fan blades power source is (steam/electric/hydraulic/whatever),,,there is NO way it takes 40HP to turn a 7 blades 18" fan at 4500 rpms with only air resistance putting a load on the motor...
LOL,,,the car makers do dumb things but no way would they have used motor driven fans with/without clutches for all those years if 40HP was needed (right at the typical oem cam HP peak rpms)....
if it was a particular pitch 7 blades 18" boat propellor test IN WATER then 40HP needed could make sense...
basically,,,just common sense is enough to tell you his fan HP numbers results have to be bogus by a mile...
and are proven wrong by many other tests articles...
New fan with adjustable temp control help redride Electrical 3 05-30-2009 10:22 AM
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 09:01 PM
Electric cooling fan Z-Money Pit Engine 1 08-29-2006 08:27 PM
Need advice on a good electric fan set up. Streetmaster Engine 13 01-07-2006 02:37 PM
? about an electric fan for PU. Streetmaster Engine 8 08-20-2005 10:14 PM
