Fan belt - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2008, 01:13 PM
KENMO's Avatar
St Louis Blues fan....
Fan belt
Is there a place I can obtain a fan belt simply by giving the vendor the diameter and circumference of the fan belt?
The last time I purchased a new fan belt for my '60 Corvette I had to take the old belt to a few places but I know the counter people didn't appreciate the task....
I did record the Canadian Tire part number but it's been lost when the diskette I had it on corrupted a few years ago....
Thanks kindly....
Kenmo
Old 06-26-2008, 01:53 PM
Does the engine differ then what was originally equipped in the Corvette? I would start off with year/make/model and then engine size. I don't forsee the parts store having trouble going by that information. In the end, your way would work... but it will be time consuming with many trips back/forth to the store after checking fitment. Good luck
Old 06-26-2008, 03:10 PM
techinspector1's Avatar
Wiki Edits: 326
This is the best I can do for you. Click on the link and choose.
0.25 = 1/4 inch = 6.35mm
0.31 = 5/16 inch = 7.9375mm
0.38 = 3/8 inch = 9.5250mm
0.41 = 13/32 inch = 10.41mm
0.44 = 7/16 inch = 11.1125mm
0.47 = 15/32 inch = 11.938mm
0.53 = 17/32 inch = 13.462mm
0.63 = 5/8 inch = 16.002mm
0.75 = 3/4 inch = 19.05mm
0.88 = 7/8 inch = 22.352mm
http://www.goodyearep.com/productsDetail.aspx?id=11752
Old 06-26-2008, 03:15 PM
Wiki Edits: 31
here is an easy way to get gates belts by length http://www.crankshaftcoalition.com/w...s_without_part
Old 06-26-2008, 05:29 PM
75gmck25's Avatar
Dayco belts are relatively easy to find, and the length is obvious.
I think a stock 350 belt will be be a Dayco 15 series (which refers to the depth/profile of the V in the pulley)
Belt number 15545 - 54.5 inches
If you have a deeper V pulley it is a different series (I have this type of pulley on a replacement AC compressor)
17525 52.5 inches
Bruce
Old 06-26-2008, 08:44 PM
lemondana's Avatar
60 Corvette belt
I have an old Goodyear belts and hose book and it calls for a 13561 belt. Not to many places carry the 13 series belts anymore. I might be able to round you up a good quality belt that is made in the US. I'll look to see if I have one and let you know in a couple days. The 15 series belts that most places sell will ride up out of your pulleys some. Leave me a message. Myron
Old 06-27-2008, 05:56 AM
KENMO's Avatar
Tossed the generator over 20 years ago in favor of an Delco alternator (3 wire). Also had to use different brackets to get the alternator on....
Thanks for all the replies....
Fan belt problem on rebuilt 406sbc 406chevelle Engine 8 06-28-2008 10:53 PM
Looking for better quality fan belt 75gmck25 Electrical 4 05-16-2007 02:54 PM
belt slippage on fan pulley? oldguy829 Engine 8 09-23-2006 10:17 AM
Squeeling Fan Belt - Out of true Pulley Billy Boy Engine 3 02-15-2005 06:51 PM
belt driven fan to rad clearance problem jcarter Engine 8 12-24-2003 12:03 AM
