fan blade - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2006, 01:36 PM
fan blade
Good afternoom
I have a 1980 Trans Am Turbo which I purchased to restore. In looking at the fan blade, I noticed that one of the blades has a larger curve (one the end) than the other six. I thought it got bent somehow and went to a local auto wrecker and they had one that was the same. Do you know if that is the way it is supposed to be or were their's and mine both bent.
Thank you so much for any assistance you can provide.
Lloyd Miller
Old 05-31-2006, 10:45 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
If my memory serves me right they {7blades} are all a little different in size & spacing.
I have noticed for some reason there is one spot where you can get to the H2O pump fan clutch bolts easer because its a little wider in the spacing might have something to do with balance or air flow .
I hope this helps you out.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 06-07-2006, 08:29 PM
Fan blade
Thank's so much for the info.............lloyd
Old 06-08-2006, 02:45 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Factory fans are often made with different blade shapes, lengths, spacing, etc to make them quieter. Take a look at pictures of replacement fans on websites that offer them as replacement parts. They look completely wierd
Old 06-11-2006, 09:53 AM
Fan Blade
Curtis, thank you for the reply to my question.............lloyd
Old 06-11-2006, 11:42 AM
RookiePerformance's Avatar
SOLT8KER
suction
The only reason the fan blades look different is because of the angle that the air comes through the radiator, once the air hits the blades it spreads and equalizes the airflow over the engine, to not only cool it from the inside, but from the outside as well!
Old 06-12-2006, 09:21 AM
fan blade
Thanks for the input Rookie
Old 06-13-2006, 11:20 PM
SOLT8KER
fan blade
No Problem.... I am glad that I can help
building a fan shroud - need help 32Tudor Hotrodding Basics 30 07-03-2008 09:01 PM
5 or 7 blade fan? pigjamelectric Engine 4 08-20-2005 06:58 PM
5 blade or 7 blade fan: what's the dif? pigjamelectric Hotrodding Basics 6 07-30-2005 06:28 PM
Fan Clutch Bad After 400 miles? Ghetto Jet Engine 10 04-02-2005 09:21 PM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
