Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fan Clutch Bad After 400 miles?
Old 04-02-2005, 05:30 PM
RCastle's Avatar
RCastle RCastle is offline
Come Home Safe Soldier
Last journal entry: Headers
HAve you thought about going to an electric fan set up? You do seem to flog the hell out of your ride on a regular basis. If you went electric you will not need to worry about losing a flex-fan thru your hood and cooling system,same for the fan clutch. I have not seen one go bad like yours has done so I would also say that the part was just defective.Was it a New piece or was it a ReMan part. They do rebuild those things too and you may have got one with a worn shaft and the seal just did not stay mated to it.
