Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fan Clutch Problems
  #25 (permalink)
Old 03-09-2007, 08:47 PM
Classix_Lover's Avatar
Classix_Lover Classix_Lover is offline
Music soothes the soul
Last journal entry: Wiring finished finally
Originally Posted by GMCTRUCKS
My 1970 GTO would run hot without the shroud even with a flex fan and it being one inch from radiator so I placed the shroud back and it was alright im going to see if this guy close to my house has an extra one I live right down the road from you off of FM-528 also how about using an electric fan that comes with a shroud you might want to check your timing as well.
Timing's just fine, I still need to fabricate the shroud. The main reason I was doing this test is to be sure the clutch was operating properly before I go through the trouble of fabbing up the shroud and just having to take everything apart if something wasn't operating correctly. Also, I did have a dual electric fan setup before but cooled inadequately; pos aftermarket thin fans, it's really no surprise why it likes to overheat at idle.
