Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fan Clutch Problems
  #26 (permalink)
Old 03-09-2007, 08:50 PM
Classix_Lover's Avatar
Classix_Lover Classix_Lover is offline
Music soothes the soul
Last journal entry: Wiring finished finally
Originally Posted by Will H
Get a hair dryer or a heat gun and heat the thermostatic spring on the front of the clutch and see what happens, I think that you will find that the clutches you have are working correctly.
I did bake the clutch at 210* for over 30 minutes and pour hot water on the spring last night. I did see the spring move ever so slightly, but to just turn it by hand to tell the difference isn't going to work. Centrifugal forces are a key factor for this I'm sure, hence needing higher rpms to really see if everything's working correctly. It was misleading having people tell you it's supposed to lock up completely and not freewheel whatsoever when it's engaged kinda threw me off at first but everything's alright now. I'll keep this thread updated once I get around to fabbing up a custom shroud.
