Fan Control Switch
Im converting to electric cooling fans on my 1974 350 sbc corvette.
I already them wired and relayed. Can someone advise me on a fan switch I can use and what temp thermostat to use. I would like to install the switch in the cylinder head. and 185 degree turn on. Im looking for a common switch in case i ever need a replacement on the road. |
You can get the whole kit here:
http://www.jegs.com/i/JEGS/555/10560...oductId=758607 Or just the switch here: http://www.jegs.com/i/Painless-Perfo...oductId=744377 |
temp switch
Thanx for the links.
I was wondering if anyone knew of an oem gm style switch at the lower temp i wanted (185 turn on)I know fuel injected vehicles run at higher temps. I wanted an oem switch in case it ever failed, replacement would be easy at any local auto store. Anyway i will probably just end up running dual switches and relays. My fan is a 2 speed. Switch 2 (185 turn on) Switch 1 (195 turn on) http://i910.photobucket.com/albums/a...g?t=1260815634 |
Here's a thread that might help you out: http://www.hotrodders.com/forum/2-sp...ch-131375.html
He's using an OEM switch from some type of Volkswagen that can handle 2 different fans/temps. It looks like one of the configurations will get you close to your temp requirements, but I don't know which model of VW to look at for the switch. |
Dual stage temp switch
Thanx so much Brimstone.
That made my day. Exactly the info i was looking for. |
I install an electric fan on 34 ford that had a 350sbc. All you have to do is go to a local auto parts store and pick a thermostat switch and install it on the intake manifold. Wire it the a radioshack 30amp automotive relay. It turn on at 180 and turn off at 175.
| All times are GMT -6. The time now is 01:33 PM. |
