Fan Delete - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 12:42 AM
LBL's Avatar
LBL LBL is offline
Running Down the Road
Last journal entry: Interior
Fan Delete
I'm changing from a belt driven cooling fan on my 351 Windsor to an electric fan and I was wondering if anyone has seen anything that would go in front of the pulley where the spacer used to go just to make it look a little nicer rather than using 4 bolts to hold the pulley on. I was thinking something aluminum that was turned with recesses in it for the bolts....just wondering ...Thanks
Old 04-02-2013, 02:45 AM
JeffB's Avatar
Check this out:Junkyard Upgrade - Dual Electric Fans - Ford Muscle Forums : Ford Muscle Cars Tech Forum
buy a new fan or use ford taurus fan daveid Hotrodding Basics 23 10-22-2009 08:38 PM
can fan blades in a small house type fan go flat? matt167 Off-Topic 4 09-15-2009 05:34 PM
fan shroud flex fan and water wetter for valiant elcaminodragster Engine 15 09-05-2009 10:52 PM
ad delete lmbj Hotrodders Site Suggestions and Help 1 10-20-2007 12:56 PM
